I vote gimmick. Ball and socket joints are designed to rotate so they can deal with different operating angles and alignments. I recently replaced my steering box with a rebuilt and it took all of the dead spot out of my steering. The original joints still rotate nice and free and I don't feel like I'm driving a grain truck anymore.
Sent from my SM-G900V using Tapatalk
WOW! Let us know how it works for you.Thanks for posting that. I need to do that to the rear axle bearing on the 4runner. The axle seal blew and caused diff oil to leak out through the bearing. I hear stories of it causing the bearing to fail cuz the diff oil washes out the grease so I will repack the bearing and hope to extend its life.
I would imagine the cost of a synthetic cable rope for a crane would be a lot more than the steel cable at those lengths and sizes it would be crazy expensive. But just my guess.If synthetic is stronger then steel. Why do cranes still use steel? All they do is raise and lower. Tow trucks still use steel and I can understand why, rubbing against rocks, trees and the ground to make a recovery.
In Construction it is the wear and tear on the synthetic rope. Steel rope gets dragged a lot, over all it it is tougher in this environment.If synthetic is stronger then steel. Why do cranes still use steel? All they do is raise and lower. Tow trucks still use steel and I can understand why, rubbing against rocks, trees and the ground to make a recovery.
X2. This is exactly correct. Synthetic is played up, and there are advantages (easier to handle, safer), but keep synthetic from rubbing things as it breaks down the fibers. The steel or synthetic iissue is another decision that should be made with your type of wheelin in mind.In Construction it is the wear and tear on the synthetic rope. Steel rope gets dragged a lot, over all it it is tougher in this environment.
In winching it is acceptable but you don't want to drag it over rocks or through the mud while winching. It will destroy the integrity. of the line.
