Glowing exhaust manifold on 2000 TJ 2.5
RAC02
Jacksonville
Hello,
My 2000 Jeep Wrangler has been real load and I noticed today that the manifold is real red, basically overheating. The engine ideal has also been going up and down as well. The only code is a cylinder 4 misfire. I know their is a crack in the manifold however I never noticed how red it was. Any help would be much appreciated!! Thanks
SSTJ
Inexperienced Overthinker
Lifetime Supporting Member
South Carolina
I don't have advice to offer about what's going wrong, but if you decide to replace that manifold, I have notes from when I did it recently on my 97 2.5.
R
RAC02
Jacksonville
Any thing would help. I just don’t know why it’s getting that red. If it is a clogged catalytic converter could I cut that off just to allow the hot air to escape? I wonder..
SSTJ
South Carolina
I don’t know but I will be eager to hear what others say.
For tips on replacing the manifold, click on my build thread and then click on the ‘Maintenance’ link, where I put all my notes.
Daryl
2004 Rubicon
Earth 🌎
Raw fuel from the cylinder misfire is being burned in the catalytic converter. If you continue to run the engine like that you will ruin the CAT if you haven’t already. Fix the misfire and check the CAT for damage.
Squatch
Master Thread Derailer
Everett, Wash, United States
Not entirely sure what you mean by this ^^^, but T from T and Daryl are setting you on the right path. I would start by dealing with the misfire first, and then perhaps be prepared to replace the cat, and even possibly the manifold. Cracking and/or warping are real possibilities with that much heat.
R
RAC02
Jacksonville
Ok I found one vacuum port on the bottom of the exhaust manifold that has no hose and from what I read should be capped. I changed my cylinder 4 spark plug and I will call the port tomorrow to see if that fixes it. O and I took the ideal control valve off and cleaned it. I’ll update!!!
SSTJ
South Carolina
If your current manifold is not OEM, there are many aftermarket manifolds that have a port near the bottom, which was used for the YJ. They are known to come unplugged over time and cause issues.
R
RAC02
Jacksonville
I put the plug on the port. It did not change anything. I am wondering if there throttle position sensor needs to be looked at? Or maybe an O2 sensor could cause it to ring rich?
SSTJ
South Carolina
Yea, I think that was Jerry's suggestion in that other thread that you just bumped for an update.
R
RAC02
Jacksonville
Have you made any progress on this?
Nope, changed the cylinder 4 spark plug, cleaned the spark plug wire. Cleaned the idle control valve, tps, and map sensor. Nothing yet has really changed anything. At first I cleaned the sensor with carb cleaner, then it drove worse, went back and cleaned with maf sensor cleaner and it’s a little better. I think the misfire is still there. I don’t have enough right now to replace every sensor so I’m guessing on which (if any could be causing the misfire). I have not replaced the 02 sensor yet. Maybe that is it. The code I get is bank 1 sensor 1.
SSTJ
South Carolina
I'm not sure, but I think that is the code for the upstream O2 sensor, right by the top of the down-pipe, where it meets the manifold.
Akitadog
Willy's Edition
The "209"
Can you check your timing?
Last time I saw red iron manifolds was when we would retard the timing to pass the old smog checks.
It would fire after the valve starts to open and burn the fuel when it was in the manifold.
Reactions: Blondie70
R
RAC02
Jacksonville
I don’t know how to do that. What tools would I need?
Fishtaco
TJ Expert
Perth AU
Last time I had glowing headers was when my motor was cooking (not jeep) and a straight 6, the head gasket was put on upside down/wrong way around blocking the water jacket holes, how is your temperature? not all cooking motors blow steam some run red hot.
