I have 35" KO's that the PO installed. They are nearing the end of their life and I'm starting to look for replacements. Because this Jeep is mostly used as a road vehicle and some minor trails, I'm considering dropping down to 33's. (I'm hoping this will also help a bit with some occasional DW issues I've been experiencing)
After doing a ton of maintenance work to bring this thing back to health, as well as having a new JKS track bar installed and new correctlync steering, I really have to be careful about what I spend next.
So my question is this: Will changing to 33's be as simple as just installing new tires? Or will any of my hardware need to change as well? I just want to get an idea of what to expect and save for.
PO installed a Rough Country 4in suspension lift (I think?) with a 1" body lift. (The RCA bushings are shot and I'll eventually need to replace.) I'm assuming the Dana35 was re-geared since I don't experience much trouble with acceleration — although I don't know much of what else was done to accommodate those tires.
Thanks for any insight you can give!
