My friend who does HVAC (for years) is having me bring the Jeep over tonight. I will bring a printout of the FSM. (Vacuum pump & a/c gauge set)
Some info on the a/c system
- I replaced broken vacuum lines with proper one from auto store
- heat works well
- blows out of all vents pretty well
- lines are not cold to touch
- compressor doesn’t come on
-compressor is spinning by hand (both ways)
-the compressor pulley, the part with the grooves is not spinning by hand
I’m thinking the system is low on refrigerant, and also, the compressor clutch might be bad. I tried to get it to spin with a paper clip off the lower pressure connector and it did not spin. I’ll get back with updates
- heat works well
