Great, this should be really really easy.@pagrey I have a doctorate degree in electrical engg with a physics minor. I am no stranger to math or springs, RC circuits, electronics, harmonics (mechanical and electrical) etc. I was not looking at specific suspension component recommendations but more about learning the design details of jeep suspension and steering geometry. The factory does a great job optimizing the ride quality, longevity and capability of the vehicle. Then we go and mess with everything by installing a lift, bigger tires and whatnot. What compromises are made when we do that? How do we recover stock performance (or even make it better)? What are the tradeoffs? At what point (or at what lift height) does geometry correction becomes really needed? These are the things I want to learn and understand. Not just "slap on this kit, get these shocks, get those brackets". I want to understand the "why".
@Sancho the 2nd video is a good starting point. The small animations are great.
You have a complicated circuit and you change the value of one capacitor. You can guess the effect. You can model the effect or you can test the effect. To guess is a total waste of time unless the circuit is very simple. To model requires an accurate circuit design and simulator like SPICE. To test you put in all the possible input conditions and test the output which is something that everybody can do.
Suspensions are the same thing. Guessing the outcome of suspension mods is a waste of time. Modeling them with a computer is a waste of time because we don't know the detailed parameters of any component which means the model wont work. This leaves only testing. See what I'm getting at, testing is the only option, knowing how the system works is of almost no use, you still have to rely on testing each possible thing and seeing if it works.
