was thinking of replacing my cable with this...its only like $25 per 10 feet...is that too good to be true/good?
https://www.amazon.com/dp/B00VXBN1NI/?tag=wranglerorg-20
what kind of winch do you have?was thinking of replacing my cable with this...its only like $25 per 10 feet...is that too good to be true/good?
the only difference i see is your model winch is 5/16 cable and this only offers 1/4 and 3/8th so i dont know how much of a difference that will makeA Rough Country RS9500
For only $50 more I'd get this known quality 100' package from TRE which includes the Safety Thimble which is a much safer and effective connector than a plain hook is. I'm running the same thing on my TJ, I've been running the Safety Thimble and synthetic 3/8" rope for probably 14 years now. You can't beat that combination. The Safety Thimble sells for $80-$100 alone so you're getting it at a good discount.was thinking of replacing my cable with this...its only like $25 per 10 feet...is that too good to be true/good?
Jerry...I've been a cable guy for over 35 years. Just went to synthetic about a month ago to give it a try. The rope sleeve you are talking about. Is that the sleeve at the hook end of the winch rope? What problems can it cause?For only $50 more I'd get this known quality 100' package from TRE which includes the Safety Thimble which is a much safer and effective connector than a plain hook is. I'm running the same thing on my TJ, I've been running the Safety Thimble and synthetic 3/8" rope for probably 14 years now. You can't beat that combination. The Safety Thimble sells for $80-$100 alone so you're getting it at a good discount.
This package... https://tacticalrecoveryequipment.com/product/synthetic-winch-rope-safety-thimble-package-38-100ft/ which is available in multiple colors.
My last order of that rope was orange, it sure makes it easier to see when in use. Also, just in case @mrblaine sees this (who also developed the Safety Thimble), I took the rope's sleeve off last year. The sleeve has the ability to cause problems when in use, I'm glad to have learned that before it happened to me.
Yes it's that sleeve that comes with some synthetic ropes. I can't explain it as well as @mrblaine did so I will just quote him....Jerry...I've been a cable guy for over 35 years. Just went to synthetic about a month ago to give it a try. The rope sleeve you are talking about. Is that the sleeve at the hook end of the winch rope? What problems can it cause?
Here is Ricky's youtube channel. Arrow to the right and watch Abrasion 1, 2, and 3 in order. The key thing to keep in mind is just how small the load is comparatively to what we do with our winches and just how fast the line wears through the abrasion guard with just 300 lbs of load on the line.Jerry...I've been a cable guy for over 35 years. Just went to synthetic about a month ago to give it a try. The rope sleeve you are talking about. Is that the sleeve at the hook end of the winch rope? What problems can it cause?
https://www.youtube.com/channel/UCY06JHaSjtTjTgyZjpkpsfg
My helper and I did the video in my driveway. This is a perfect example of knowledge does not equal understanding.
It has gotten to the point where Ricky has difficulty selling a winch line without the "abrasion" guard on it because folks lack the capacity to do any critical thinking and instead just want to believe bullshit. We've been removing and cutting the nylon sleeves off of winch lines for at least 10 years due to all the problems we've had with them and trying to get folks to understand why they are bad is just about impossible. Those videos should have 1000's of views and they have less than a 100.Great video, thanks for sharing it. Your last quote says it all.
