Does anyone have a Gr8Top full top for a TJ? Any insight on durability and everyday usability? Thanks!
I've designed several Safari style hardtops, including the one that Gr8Tops now sells. The one Gr8Tops sells started as a DIY project for my LJ and when I finished building it Gr8Tops approached me and licensed the design. My homemade Safari Cab is now 11 years old and still going strong, just got back from a week on trails in Colorado. Took this photo a week ago:@jscherb would be good to hear from ...He has Been involved in the development of some of the safari style tops. He is a gifted person.
The rear barn door upper removes with a couple of bolts. The bracket Gr8Tops uses to attach the barn door upper to the tailgate is different than the one on my Jeep, but it's functionally the same.Thank you so much for responding. So the production top does not have removable sides? How about the rear barn glass? Can you remove it the same as a factory Hardtop?
Great timing on this thread!
I've been driving a 97 TJ since I bought it in 2000. I've always wanted a hardtop with soft sides. My newly-driving sons are both wanting the TJ, so a few months back, after discovering the Gr8tops Safari Cab, I decided on an LJ. Finally found a low-miles example with the right color and 6-speed (in my profile pic). Drove it home last week.
I'm not too far from Gr8tops, so I plan to order one and drive down to get it sometime in the fall. I've got two questions for @jscherb (for now):
Thanks in advance!
- Any info you can provide on making full soft sides would be greatly appreciated! Do you have any drawings or plans you could send? There is a local shop that does alot of custom car and boat upholstery & boat covers that I think could handle this for me.
- In the "continental divide" pic, it looks like you have a basket on the rails that are offered by Gr8tops. Is that correct? If so, what basket is that? Would you recommend using their rails option, or would you recommend another option? I'd like to be able to put a few hundred pounds up there. No car-top tent.
Chris
As I designed the Safari Cab, there are notches in each rear corner of the drip rail to let water drain out the back. I don't know if Gr8Tops adds those notches to the production drip rail.@jscherb - Hey Jeff - On your top, where do your rain gutters empty out, over the front windshield like Gr8Tops? Do you have anything on the rear? The gutter hold water until you go downhill so curious if you have a different solution.
@merrill77 - I did reach out to Jeff who put me in touch with Morryde about buying rear stanchions, but I had to order multiple sets which was illogical. If you go that route let me know as we could try to find another guy to reduce the cost.
While I love my hardtop, I wish there was an option for a better build quality. I had my top rhino lined since it had way too many holes.
Zoom in to see the rhino liner.
Prior to being rhino lined
View attachment 277550View attachment 277551View attachment 277552View attachment 277553View attachment 277554View attachment 277555
I'm traveling and don't have a photo of the notches in the TJ/LJ drip rail handy, but here's a photo of a similar notch in the drip rail of the JKU Safari Can drip rail:
Gr8Tops changed the drip rails from my original design when they put the Safari Cab in production. They did a nice job and I believe that on their version the drip rails are stronger than my original design. But it's not my place to make strength claims for companies - if I made a claim about the strength of a product and the product failed for whatever reason, a company could reasonably say that since they didn't make the strength claim, they won't provide any warranty support for the failure. I wouldn't want to put you or a company in that position, so I think the best thing to do is to try to get a definitive answer from Gr8Tops that they will warranty.I can confirm there are no notches in the rear, at least not on the LJ version.
@jscherb Jeff, could you opine on whether rain gutter roof rack mounts would work on your design? Honestly, Gr8tops customer service, in my experience, is not great, and I'd rather ask the designer himself.
Back when I finished the CJ Grille Kit for the TJ a company was interested in marketing it so I worked with them on a cost analysis and arranged to have the manufacturing done for them by a quality fiberglass shop. But in the end I think they decided there might not be enough demand for the kit to put it into production so they didn't go any further.So, Jeff, did you ever put that CJ grille conversion into production. I saw the design thread on another forum a while back.
I'm getting ready to go to high line fenders and I'm not crazy about the little LEDs that they use for the turn signals after the fenders are cut. This grille would be a nice solution.
