I worked for many years in the HD trucking industry. Learned a lot about different greases so I thought I would share.
Most of you already know that you should be using a good quality (NLGI) GC-LB rated grease in #2 grade for most climates. "GC" being the highest rating of chassis lube, "LB", the highest rating of wheel bearing lube. The color red seems to be in vogue in most circles.
But in the HD world, Spicer recommends only one grease for their u-joints and slip yokes and that is Chevron Ultra Duty EP2 in grade #2 regardless of outside temp (hint - warm up the gun indoors if you intend to grease in January). This grease is ideal for all your tie rod ends, draglink ends, and ball joints. It's is extremely tacky and will protect better than most GC-LB products even on your Jeep. It's not suitable for wheel bearings so don't use it on your trailer bearings. Don't assume synthetic anything is better. Great for your motor, not important for a grease joint and in fact, many synthetic greases do a poor job of protecting in Extreme Pressure applications.
https://cglapps.chevron.com/msdspds/PDSDetailPage.aspx?docDataId=77100&docFormat=PDF
Just about any HD truck dealer carries this in your neighborhood and it's not expensive.
If you need a grease for pins and shafts under extreme load, trailer balls, greaseable trailer spring bushings, etc, then you need to buy a 3% moly formulation.
