So when i pulled off the instrument panel i found thid ground strap with a small blac wire connection that goes nowhere. any idea of where this would normally tie into. i have looked but cant find a missing port or bare wire anywhere
Check in section 8W of the FSM which has wiring colors, gauge of wires and harness pin out numbers.
Here is a PDF that can be downloaded to assist you in troubleshooting.
