Front: https://www.amazon.com/gp/product/B00QWX6KQM/?tag=wranglerorg-20@EJD , do you have the part numbers for the ranchos ?
Again thank you. Did you have to add any spacers or bumpstops ? Wanting to make sure I get everything together so I can make it a weekend swap. My Jeep has a 4” skyjacker lift on it currently. I am wanting to go back to pretty much stock and 31” tires.
At the time I replaced my Jounce Cups: https://www.amazon.com/gp/product/B01LZCDBQ3/?tag=wranglerorg-20Again thank you. Did you have to add any spacers or bumpstops ? Wanting to make sure I get everything together so I can make it a weekend swap. My Jeep has a 4” skyjacker lift on it currently. I am wanting to go back to pretty much stock and 31” tires.
After cycling my suspension, I ended up needing about a 3/4” spacer in the front that I put on the lower spring perch.Again thank you. Did you have to add any spacers or bumpstops ? Wanting to make sure I get everything together so I can make it a weekend swap. My Jeep has a 4” skyjacker lift on it currently. I am wanting to go back to pretty much stock and 31” tires.
What type of spacer did you use ? I have a dirt works rear bumper ,tire carrier , also has a rack and carries 2 5 gallon Jerry cans. I have a lot of weight on the back.Mine were blue as well, I did add a 3/4" spacer in the rear to level out the factory rake.
I have the Daystar kit: https://www.amazon.com/gp/product/B001GH5OF2/?tag=wranglerorg-20These ?
Rubicon Express RE1333 75" Coil Spring Spacer https://www.amazon.com/dp/B006GJLKZ8/?tag=wranglerorg-20
just a normal rugged ridge rubber pucks from Amazon.What type of spacer did you use ? I have a dirt works rear bumper ,tire carrier , also has a rack and carries 2 5 gallon Jerry cans. I have a lot of weight on the back.
I plan adding a winch to the front with a stock bumper.
If this is still true, let me know! I'm probably way too late.Just in case anyone is interested in a set of the 52107 H&R springs - I have a set for sale. They have not been used - but I decided against using them and cannot return them for refund. I've listed it in the classifieds on this forum. Thanks.
I am a little late to the game here but I can help you with this one Chris. I am currently running a H&R setup with budget boost spacers and 32 inch tires. Everything works fine with Budget Boost build. If you need photos, just let me know.Old thread here but wanted to ask the guys who are running H&R springs are you running 31's with no body lift or possibly 32's ?? I ask because I am currently installing these springs in my 1998 TJ still have had originals factory springs all this time and yes it was unsafe these last 3-4 years to drive it out the neigbor hood. It seems like I have so much dang lift with them granted I have not put the fuel tank back in as I am waiting for the 3/16" skid plate to get powder coated and the heavy rear 3/16" bumper isn't installed either. I'm blown away how much lift it is. Its got a 1" body lift I installed many years ago which will be getting removed and thrown on the shelf. This jeep is a soft top so that to maybe why it seems like I have so much lift? I seriously wonder if 32's would fit? I prefer to stick with 31's because of gearing. Will these springs settle after a bit? Thanks
Correct, but I used a 2 inch in the front and 1 inch in the back to give a leveled appearance. I did not have to use a SYE. May I ask who is doing the re gearing? Currently looking locally.
