Their jack stands were recalled for collapsing on peopleI have jack stands that are not harbor freight but are made in china...I don't think there is much difference.
Yeah, I know they were recalled. Don't know how many actually collapsed on people...but still. I think you run that risk with anything made in China.Their jack stands were recalled for collapsing on people
yes we do.we've got wires crossed
didn't see that anywhere.The OP mentioned strap is kinetic
And what's the heaviest vehicle weigh? or you gonna buy 4 different rated ropesThe rope should be 3x the heaviest vehicle, not 3x just the recovery vehicle. If you’re recovering 10,000lbs with a 4000lbs vehicle you certainly want a rope rated higher than 12k.
Everything written about sizing rope clearly states that the rope should be at least 3x the vehicle you’re recovering, not the recovery vehicle. Argue if you’d like. The literature is clear.
There are cheaper ones that are 3" wide. I like one about 3"x12' long and rated 17,500lbs.Has anyone here used this strap before? Looks like a decent deal for a weekend warrior. Let me know your thoughts
https://www.harborfreight.com/6600-lb-capacity-2-in-x-20-ft-recovery-snatch-strap-58064.html
I think those are the tow straps you are referring to.There are cheaper ones that are 3" wide. I like one about 3"x12' long and rated 17,500lbs.
ya i got hung on the stretch thing a bit . max stretch is fully loaded and approaching the break point. so we want a rope or strap to work in the 5-25% range of a 30% stretch, would this be accurate?keep it simple, whatever vehicle you are carrying it in then use the manufacture recommended weight multiplier.
4000x3 is 12000(Jeep’s)
6000x3 is 18000(full size trucks)
12000-20000 range is probably reasonable
That gets you keeps and 95% of what you are going to see off-roading
I use the ARB which is 19500…I get plenty of stretch and it’s smooth…mission accomplished. I get the part about inconsistency in recommendations by manufacturers.
Mine is marketed as a tree strap, but I also use it to pull someone out if needed.I think those are the tow straps you are referring to.
We are discussing kinetic ropes/snatch straps…they are more expensive and superior to regular tow straps for recovery. Not being a dick, just clarifyingMine is marketed as a tree strap, but I also use it to pull someone out if needed.
