Russ Mullen Member Joined Oct 18, 2018 Messages 94 Location Northern VA Nov 11, 2018 #1 I'm missing two of the mounting bolts, and I think the seals might need to be replaced also.
fxrsliberty TJ Enthusiast Joined Oct 3, 2016 Messages 226 Location Renton Nov 12, 2018 #2 You mean these https://www.quadratec.com/products/11190_9906.htm Sent from my Pixel using Tapatalk
fuse TJ Enthusiast Supporting Member Joined Jun 5, 2018 Messages 706 Location San Diego, CA Nov 13, 2018 #3 If you're looking for bolts to hold the hardtop to the tub, these work well: https://www.amazon.com/dp/B06XTHXPZH/?tag=wranglerorg-20 There are other options on Amazon too. For the seal, this is the best stuff I've tried: https://www.amazon.com/dp/B000052031/?tag=wranglerorg-20 Notching the seal so it bends nicely at the rear corners helps to keep it in place.
OP Russ Mullen Member Joined Oct 18, 2018 Messages 94 Location Northern VA Nov 13, 2018 #4 Fantastic. Thanks guys
