Trying to work out where these leaks are coming from on both sides is it just bad seals that need changing?
I think it may be the seal between the sides of the hardtop and rear window that has gone and water is running down into those corners.
I could hear dripping so removed the vents the seals were completely gone, have tried these mopar replacements but they are a good half cm short compared to the oem vents (maybe the size changed slightly for different year hard tops?) I will see how it goes.
View attachment 1362 View attachment 1363 View attachment 1364
it rained pretty heavy yesterday night and went down to check, no water came on the left side. but same issue on the right side, I'm assuming this is because the mopar replacement vents didnt fit as well as i can slide the covers up and down. I am going to use stixall or some other marine sealent just to seal them down properly
i was reading that the vents were needed for the AC to work correctly, I guess thats not true if they ditched them on later models.
Im going to use U-Pol tiger seal black around them when i get some free time.
that sounds pretty out there, i mean these wranglers are not exactly the most air tight vehicles on earth
haha i dont want to be "that guy" either.
