...and maybe win the Nobel prize...
Wanna make a quick million and finally put an end to all war and famine?
@Ranger_b0b @glwood @ElectricWizard @jjvw hope you are all following this thread. I think I know what's happening. I would really appreciate if you guys read through and see if there is anything that is not consistent in what I am saying
@psrivats I've kept up, though I haven't read the paper you posted in its entirety. Interesting thing about that bell housing inspection plate...I have an 04 with a manual, and the inspection plate (the part that is vibrating in Dave's video of Sri's jeep) has a bolt at the bottom to hold it to the bell housing.
You also asked earlier in the thread if the 4 cylinders are different that the 6 with regard to the disturbing frequency. You are correct. That formula is simply calculating the number of explosions that happen at a given RPM, and converting to seconds (to put the units in Hertz). A 4 cylinder will have two less explosions at any given RPM, so the disturbing frequency will be 2/3's that of a 6 cylinder at any RPM. Basically, what is happening in the engine when the air fuel mixture ignites (the controlled explosion that drives our jeeps) is it creates an acceleration pulse on the crankshaft...which will then transfer through the drivetrain. The fact that ALL manuals got a harmonic balancer makes sense, because a manual is "locked" into the drivetrain at all times (well unless you push the clutch). The torque converter on an automatic will allow for some "slop" in the system so it may or may not need a balancer.
I'm going to have to spend some time working out how harmonic balancers are designed.
If you come up with a harmonic balancer design that is adjustable, fixes this issue, and can be manufactured, you won't be able to make enough of them...and maybe win the Nobel prize...which you'd have to share with @psrivats...
I'm heading over to Jeep West in a couple hours. I'll post back on findings. Wish me luck gentlemen!
You'd think drive shaft makers would have figured out a solution for this.
I bumped the WF thread for an update.
I'm interested for Blaine's opinion. IMHO, he is the most knowledgeable of anyone on the forums.
