I'm using the kit, it's cool.
I've installed and used many of them. What difference are you looking to make?Good deal I’ve been looking at it and I believe it would make a difference.
Thanks for the the reply.
I've never found the stock bushings to be the limiting factor and with the Currie stuff installed, I don't believe any of us would be able to tell the difference. I'm not against them, I use and install them, I just typically can't tell the difference.Just to loose the binding from the stationary stock set up. I think with all the other connections being JJ this would be nothing but improvement and let all the control arm points move the same or equal.
What do you find to be the limiting factor? I thought the reason for the Johnny joint is to improve articulation.I've never found the stock bushings to be the limiting factor and with the Currie stuff installed, I don't believe any of us would be able to tell the difference. I'm not against them, I use and install them, I just typically can't tell the difference.
Limiting factor is nearly always the body, flares, and shocks.What do you find to be the limiting factor? I thought the reason for the Johnny joint is to improve articulation.
School me on the point of these joints?
