Talk about raising the bar.Installed:
A few details involving gun racks and quick fists and it's done.
Awesome job. !!
Thank you @billiebob. It turned out pretty nice, didn't it. A few details to refine, and a couple of bits to purchase and it's done. Better security and improved organization is nice.Talk about raising the bar.
Awesome job. !!
I tied them into the rear seat mounts. Used bushings and spacers to get a solid attatchment. Tapped the center hole in the strut 5/16 and bolted the deck down to that on each side. It turned out to be a lot more rigid connection than expected. Gave me a little adjustment as well for leveling.Looks good!
Is the 80/20 mounted to the tops of the wheel wells?
This thread details my 3 versions of a cargo basket/shelf. (I absolutely love it!)
https://wranglertjforum.com/threads/custom-cargo-basket-storage.8648/
Only posted this in case someone following your thread is looking for other possible basket mounting options.
I really like that Jerry can mount you have
Nice work so far...I love a custom job that is tailored to fit you and your needs.Got the Scepter water can today. It fits the Motobilt can holders, but the tie down link doesn't fit. Didn't figure it would. A 3/8" eye bolt and a small ratchet strap will work just fine.
Now to get the axe, first aid kit, fire extinguisher and rifle mounts on it.
Oh, and fix the deck rattles when it's empty.
Thanks Kiwi TJ. This one has spent some time rattling around in my head...Nice work so far...I love a custom job that is tailored to fit you and your needs.
Those are the best ones to have.. You work out all the pros and cons as you ponder different scenarios then you can tweak your ideas....Thanks Kiwi TJ. This one has spent some time rattling around in my head...
Thank you.Looks great, good job!
I need to know more about those clamps holding the axe...
@StG58, Nice job!
Looking forward to the load out pictures.
The quick fists are available at a lot of locations.
Here’s a link to the manufactures site to help someone see what sizes they make.
https://www.quickfist.com/index.php/quick-fist-mounts.html
Is that rear rack roll bar mounted or tub mounted? Who makes it?
I used the the seat belt mounting bolts and an angle bracket to tie the back of the basket to the Jeep. The brackets hold the basket up enough so the carpet is still removable. The front is mounted to the rear seat brackets on risers.Is that rear rack roll bar mounted or tub mounted? Who makes it?
Thanks
Thanks
Here ya' go! Basket mounts.Is that rear rack roll bar mounted or tub mounted? Who makes it?
Thanks
