Be sure to flush the core from both directions. This will get the maximum amount of crud to get flushed out.
@Black-Bear- my top hose connects to the top Inlet same as your. 2001 4.0.From the top of my thermostat housing the tube goes to the top port of the firewall. In the FSM it goes to the bottom port on the firewall. Any ideas why this would be? Maybe the previous owner connected it backwards?? I just picked up this jeep 2003 rubicon and have been following this forum trying to get fluids tuned up first and for most. Working on following the radiator flush thread today.
I appreciate the help!
This is true , the top of the heater core has the large port. The FSM pic has them swapped.I think @DrDmoney pointed out recently the hoses are different sizes at the heater core and cannot be swapped. If they are on then they are probably correct.
It appears you misread post #22 and post #25. The only person that has recently mentioned "flush" is you and post #24 which is obviously in response to your post. To be clear, nobody but you in January has been talking about a flush. The recent posts now are all about how the hoses are mounted to the firewall.We are talking about back flushing the heater core. Not how the hoses are normally used.
No difference in which hose goes on top. It is a simple heat exchanger that has no "right" way to flow water direction. Mount the hoses the way you want to. When flushing the heater core, then it is important to flush the water thr8both directions to get the max gunk removed. I would flush backwards first. This will help push gunk out of the core 'backwards' if you flush 'forwards' first you will be pushing gunk into the core, through, then out. Hopefully that makes sense to you.
Just want to make sure i understand this correct(please don't judge, very new to fixing things alone). the picture from the owners manual makes it seem as if the hose from thermostat to heater core should go to the bottom of the heater core, and opposite for the line from heater core to water pump.View attachment 186728
Confirming it doesn't make a difference? I just replaced my radiator, water pump, thermostat, etc. and mirrored how all the hoses were connected before. I have a leak from the water pump hose, I'm about to replace that and I want to make sure I replace it the correct way and don't run into any issues later.
Any tips and tricks are appreciated.
Thank you!!The rule of thumb for just about any hydronic coil is supply bottom return top as shown in the diagram.
I just saw this about how the heater hoses are routed from the thermostat to the heater. Jerry's comment and the diagram say the hose from the thermostat goes in the top hole on the firewall. i've had my jeep 8 years now and am replacing the heater hose from the thermostat but it runs into the top hole on the firewall. Has that thing been hooked up wrong the whole time? The heater works fine.The larger return hose from the thermostat housing connects to the bottom port on the firewall.
Answered my own question. doesnt really matter but hooking up to lower allows air in system to bleed out better.I just saw this about how the heater hoses are routed from the thermostat to the heater. Jerry's comment and the diagram say the hose from the thermostat goes in the top hole on the firewall. i've had my jeep 8 years now and am replacing the heater hose from the thermostat but it runs into the top hole on the firewall. Has that thing been hooked up wrong the whole time? The heater works fine.
I'm also just noticing this Figure is for the 2.5L, but the one posted by Jerry for the 4.0L gives me the same impression.
Not true, the one I posted above in post #8 was for the 4.0. Look at the bottom of the illustration posted there next to where it says Fig. 1. And look at the very bottom of the one you just posted, it's the same one and it still says it's for the 4.0.For the record, the one posted by Jerry is actually for the 2.4L I just found it in the FSM. View attachment 276209
