I have run into an issue and need some advice. I replaced my rear driveshaft with an Adams today and after I was finished I went to drive the Jeep and the shifter felt stiffer but went into drive and I drove off. Well I went to turn around and realized the shifter would not go into 2nd or 1st and was easily jumping into neutral. I then had trouble getting it into park. I moved it around and it then moved to 2nd but still not like usual. My biggest concern is how easy it moves from drive to neutral to reverse without pushing the button now. Never done this before. Any idea how to resolve this? I removed the shifter and the white beaded insert was still solid and would not come out. I then removed the console and watched the linkage move there and under the Jeep but I saw nothing blocking or causing the issue. Thanks everyone.
