Wow, that thing is toast! Looks like somebody is pulling a crank pulley.
Lol! Yep! I'm not sure to whether to be happy or depressed.
From what I've researched, getting to the timing chain is no easy job, possibly harder than this one so far! I'm glad you mentioned it though, or I would never have even thought to check it. Thanks!
That timing chain is loose, how did the plastic wear strip in the timing chain cover look? You have to use a bar move the crank back and forth to check the trust bearing clearance, the crank will not usually move by hand.
Honestly, I'm not sure what the plastic wear strip is so I didn't think to check it today. I will look it up so I know what to look for, thanks for the reminder. And thanks for the clarification on moving the crank, I will try that out tomorrow and see if it budges at all. I made a mistake in the video and said that the thrust bearing is in the middle main bearing, but I was wrong, according to the FSM it's in the 2nd main bearing. If there is play in the crank, I will be pulling that one and checking it for sure.
I do have to say that that rear main cap was really dirty, especially on the side facing back towards the flex plate. I can totally tell that the rear main seal is bad. I think it's important to change those when we notice oil leaking because it sure looks like it leaks both ways; meaning that oil gets out, but dirt also gets in. Those crazy gouges in that bottom main bearing could have gotten much worse. Luckily, as I said, the crank seems to be super smooth without any scoring, but I will inspect it again when I replace that bearing just to be sure.
I do have to say that I'm glad about the way things are playing out so far. Sure, it would be nice to know what the knocking sound is for sure, it would be nice if it was easily apparent, but I am quite relieved that the bearings, rods, crank, etc, all seem to be in good condition. I love this Jeep and I want it to keep running for a long time.
So I will keep going until I find the problem. So far my possibilities are:
-timing chain noise (But it's on the front of the engine and the sound is at the rear)
-Bad thrust bearing (Crank seems really tight, but will check with a bar)
-Cracked flex plate (no way to tell yet unless I pull the trans)
-Lifter noise (But would you hear this on the bottom of the engine and not the top?)
-Cam shaft bearing? (Not sure how to check this, the camshaft seems really tight though)
Thanks guys!
