I am working on my 2006 LJ auto. Not a daily driver. Lives at the beach.
So the girl just got brand new wheels and skins, and she rewards me with an apparent leak! On the way home from the tire store I noticed a slight smell and she was smoking under the hood lightly when I parked in the driveway.
I crawled under and noticed a lot of oily spray back on the drivers side oil pan, trans lines, control arms, and drive shaft. Definitely something coming front to the back.
My trans cooler lines have been looking iffy for some time, there seemed to be a lot of residue along the lines, especially near the factory plastic retention clip. I figured it was time - so I ordered new SS lines from Lines To Go. This morning I successfully disconnected the lines (06 has the quick connects x4) and was prepping to remove. I realized getting them out and the new in might be a problem due to the bends and routing. While studying them I noticed oil drips higher up on what I think is the AC compressor. I recently had a refrigerant leak diagnosed but have been nursing it after a recharge. It had been staying cold so figured it was a slow leak.
Now I am thinking it might not be the trans lines. But is there that much oil in the compresssor? I have attached photos. If you zoom in you can see a drip of golden colored oil forming at the bottom of the housing. Is this what is leaking all over??
If it’s not the trans lines, I at least know it’s safe to drive.
Thanks for any thoughts.
