Ok so I need a new O2 sensor- as does everyone. But the P0158 just popped: O2 sensor circuit high voltage. Is this a sign I really need to replace the O2 sensor? Is there anything else I should be looking at?
P0740 just started for me this week. I have been experiencing a long crank time, unrelated to the fuel pump (I just changed it). I have replaced spark plugs and am checking out the injectors but so far that all seems fine. Could P0740 possibly be causing my long crank issues? I’m not having any other issues with the transmission, or any of the symptoms I see online when I look up this code.
However, I discovered yesterday that the breather valve on the TC is completely disconnected and I am going to replace that hose. Could this possibly cause P0740?
