Hi, about a week ago my 2.4L on my 2003 began running rough and I found out it was a cylinder 2 misfire. I replaced the plugs and no change. Today I replaced the wires and still no change.
Should my next step be to change the coil or swap the injectors to see if that indicates a bad injector? Or should I just buy some new better injectors and see if that does the trick?
Thank you!
Thank you!
