A few questions. I am fairly positive that my Jeep has a dropped pitman arm. What I am trying to figure out is if the track bar the PO installed requires the dropped pitman arm. The lift is a 5” lift and from reading other threads I can still run a stock pitman. Is 5.5” the max for a stock pitman? (I’m not going to lift mine anymore it’s just a question for my SA). Last question is what is the name of the part that the track bar connects to on the driver side? I need to replace mine because the track bar moves up and down at that point.
If you all see anything else messed up in these photos let me know!
