Looking for help on Spare Duratrac tire 31x10.5xR15 on Alcoa Wheel (Rocky Mountain Edition) that won’t fit on stock spare tire mount. It looks like maybe due to back spacing and the 10.5" wide tire that the snubbers are in the way. Here is what I have been able to come up (See Below I-V) with reading the forums. Looking for any suggestions to correct it and mount it. I appreciate any help!
I. Remove or trim Snubbers. Stock brake light may need washer lift or trimming.
II. Use 1-inch wheel spacer
III. Add washers between the tailgate and the stock spare tire mount to push stock spare tire mount away from tailgate.
IV. Replace lugs on stock spare tire carrier with longer lugs —-> Sounds too complicated for me .
V. Go with what @Chris used, which looks like Rugged Ridge 11585.01. I assume with moving out 2 inches, I would need to add hockey pucks, pvc, or add and trim/cut second set of factory snubbers recommended by @Jerry Bransford to get the snubbers to touch the tire again.
