Help! Possible cam or crank sensor issues?
Ivyrlloyd98
Hello, so I have been having some issues with my jeep. It usually waits till it’s heated up. It will hesitate and jerk kinda bad, and oddly enough seems like it really does it when I got over bumps in the road. The RMPs don’t drop but the speed does? But I’m not slowing down that much. Like it drops from 50 mph to like 10-20. Amd I’m still going 50 I’d say. It also stalls out at stop lights sometimes if I let it out of gear or just have my clutch in to drift. Hesitates to start back up. I just want to know what you all think! It’s got a 4 cylinder motor, 1995
TeeJohn
Kentucky
Does not sound like my crank sensor failure symptoms. If you really feels it’s triggered by bumps, check out wiring harnesses that run around the engine and transmission for rubbing and pinches. Check that the chassis and body grounds are clean and tight.
