My 2003 TJ SE with the 2.4L motor and Mercedes ZF steering gear has had a leaking steering gear input seal for months. I finally found this post http://www.rubiconownersforum.com/f...1757-steering-box-input-seal-replacement.html that walks one through the rebuild.
My rebuild failed. I think one of the loose ball bearings in the ZF style box got loose in the housing, made a terrible grinding noise after I bled the lines and started her up. It's scary, and also undrivable. I do not want to drop $500 on a rebuilt ZF box. So I have a few questions about going to a Saginaw box.
1. Can I use the stock power steering pump that I already have?
2. Will I need new lines? I just bought brand new high pressure and return lines for the re-installation ZF box setup.
3. Will the steering shaft from the steering wheel fit the splines on the Saginaw box, or does that need to be replaced also?
4. The ZF Setup used ATF4 instead of power steering fluid. Is that a function of the pump, or the gear box? What fluid would I use assuming I reuse my pump with the Saginaw box?
I know that's a lot, but I just don't want another mistake to keep me from enjoying my Jeep! Thanks!
