Help with Currie Currectlync steering part numbers
justjake843
Charleston
So I'm replacing the drag link on my Currie steering on my tj, and I managed to booger up the threads on the passenger side tie rod end on the tie rod, and I'm not sure which part to order. I see there two different tie rod end part numbers
ce-9701trr
Or
ce-9701trl.
I understand that this means left or right aide but which side does Currie consider the left or right side of the vehicle? (Passenger vs driver)
Basically I'm not sure which part to order
Blackjack
Evil Winch Doctor
Kenai
ce-9701trr
Or
ce-9701trl.
Check your threads. R&L on the part number typically refers the whether it is right or left hand thread and not its position on the vehicle.
Blackjack
Evil Winch Doctor
Kenai
I forgot to ask how bad are the threads? Sometimes some patience and a thread file will often time save the day.
justjake843
justjake843
Charleston
The threads are rough. I stupidly tried to beat the joint out of the drag link hole with a BFH with the castle nut halfway threaded on
CharlesHS
TJ Expert
Lifetime Supporting Member
Jacksonville FL, Quezon Philippines
Have you considered chasing the TRE threads with a thread die ?
cpwolf
Texan
TEXAS - Cedar Park
On the tre joint?
I woufl actually consider fixing the threads. I’d chase with the correct thread die and see how they look. If it terrible mushroom, a little file and then the die.
jjvw
secret beadlocks
Colorado, USA
What is wrong on the drag link that led you to want to replace it?
justjake843
justjake843
Charleston
I traded a set of wheels/tires and didn't realize the tires from the prev owner were cupped real bad, and couldn't get new tires for the longest time, and since it was my daily driver it led to causing the tre on the drag link to become bad (figured it out by a dry steer test after experiencing death wobble).
I'm not sure about doing thread repair because the joint just spins and spins after attempting to try to out the nut back on in an attempt to try and reshape the threads
jjvw
secret beadlocks
Colorado, USA
You can squeeze the tre housing back together with a shop press to tighten up the pin.
This is my Currie steering...
Reactions: Rickyd
