Help with iac valve tps sensor
Damageinc
Indiana
Hi, I have an 05 Wrangler 4L 6 speed and was getting a high idle in neutral and between shifts. No codes or check engine light. Read it was either the iac or tps, so I bought both at O'Reilly's . Took off throttle body cleaned everything and installed new parts put on new tb gasket ad fired it up and now I have check engine and code for iac and it's idling rough and inconsistent. I disconnected battery for a few mins and tried again but same thing and I drove it around awhile and no change. Are the parts I replaced bad?
yes a good chance the sensors you bought are bad. You really should only use factory OEM sensors on the Jeep. the Jeep's seem especially sensitive to using oem sensors only.
I tried a higher price store-brand TPS last summer and then spent a month trying to find a problem that never existed. Swapped out for an oem and has ran perfect ever since. return those parts the store, get an oem off Amazon so you can return it if you need to and a good chance your problems will go away, or at least narrows it down.
Reactions: Blondie70
