I have a Stihl HS46 gas hedge trimmer. Currently it will only idle, when I try to accelerate the engine is just bogs down.
I have adjusted the carburetor high speed, low speed and idle speed settings according to the owners manual.
The machine is about 5 years old and has been well cared for and used less than 12 times a year.
I have inspected, cleaned and re-lubricated the gear box and it turns easily.
The air filter is original but the engine performance does not improve when I take the air filter off.
The spark plug appears to be in great condition.
Fuel: I only use ethanol free fuel in all my small engines. It is properly mixed in a 1 gallon can with Stihl synthetic oil (their highest grade). I recently put the proper amount of Seafoam in the fuel mixture to help with a performance issue with the blower and it seemed to help. The same fuel is in a blower, line trimmer and metal blade edger, all work perfect.
The trimmer was working normally then it started having issues running at proper RPM. The issues got worse quickly and within 10-15 minutes of use since the issue first came up it was unusable.
Any ideas of what is going on here? I have time and a teenage helper, I want to get my bushes trimmed! The engine will start and idle normally but any attempt to rev up the engine and get the blades moving results in a bogged down engine and no increase in RPM.
