I just did a 2" lift on my 2005 Wrangler Sport. Not sure exactly how much my original suspension was sagging but my corners changed between 2" and 2.75" after the install. My install included:
- front lower adjustable control arms
- front adjustable track bar
- front swaybar links
- rear track bar relocation bracket
- Rancho RS9000xl shocks
- 4 progressive springs
Now, to my question regarding the pinion angle and the vibration that I have during acceleration. In measuring my rear driveline geometry I have the following measurements:
Transfer case yoke: 4 degrees (pointing down)
Axle: 14.50 degrees
Rear pinion: 9 degrees (pointing up)
The measurements surprised me to be off by so much. So, what would you do to correct this problem?
Thanks
Axle: 14.50 degrees
Thanks
