Removed my A/R and started installing a new Swayloc.
I have a couple of questions for those in the know. On the passenger side it is not clear in the instructions which way the inner bar is be installed. Should it be installed as I have it in my picture or should it be flipped over to get the two parts closer together. Second question is at what angle should the bars be at when installing the links ? And which hole are you using to connect to ? on my A/R I was connected to the second from the rear hole.
Thanks for your help
