So I removed the rear drive shaft. Its a double cardan for my 05 Rubi thus not stick. Spicer appears to be stamped all over it. Ive searched for awhile and am still confused as to which part #s I need. The two u-joints on the ends appear the same, hell all 3 look the same, but there are different letters stamped on the caps.... Thanks in advance for any words of wisdom.... so confusing. The spr 539 I find in Moog. 529 keeps popping up as an alternative and I cant see the number on the center joint. Are these cross referenced??
