I am hoping someone has had a similar issue as me.
I have a 2005 TJ 4.0 IL6 Manual.
At random times, RPMs and Gears, my Jeep does what I would call a "hicup" and seems to studder for a half a second. No check engine light and no codes are thrown.
If I am in lower RPMS and gears and I press the clutch in I can save it from stalling. If I don't press the clutch in, in lower RPMs and gears, it bogs down and eventually dies. Also, sometimes after it bogs down, it is a very rough start not starting again for 5 minutes or so.
In higher RPMs and gears, it will "hicup" for a split second but pick right back up like nothing happened...
This issue has gone on since this September. Sometimes it goes days without an issue. Sometimes it happens 10 times in one trip...
I have yet to see any sort of pattern.
I have taken it to 2 different places both of which have not found any issues.
Fuel compression was checked and grounds have been checked with no issues.
Someone mentioned fuel pump/filter assembly and also a possible chip reciever for my key. (The key is an aftermarket key that came with the jeep).
Can anyone shed some light on this issue please!!!
