Stop thinking of your bumper and Hi-Lift as the right tools for changing your tires. Neither is appropriate nor safe, nor is anything more than the factory jack needed. The factory jack is more than up to changing 35" tires and even 37" in a pinch.I was kind of wondering the same thing. My scissor jack broke, but I have a hi-lift. I know my bumper is strong enough, but what about the couple of bolts holding it on??? For those that have tried it, did it bend your hardware?
This is where you should be jacking from, this shows my 35" tires several inches up off the ground with the OEM factory jack.
You're not wrong at all!I have 33's and I thought that the best place to jack while standing in flat terrain was the diff or the axle if only one tire is needed to be lifted... am I wrong? I've never had any flat tire in the trails but I always carry some wood planks next to my subs and recovery strap to lift a bit my jack if needed.
eBay sells multiple used OEM TJ jacks nearly every day.I agree the hi lift is over kill/not the right tool most of the time. Like I said, my OEM jack broke and needs to be replaced. So in a needs to be situation, would jacking the after market bumpers damage/bend the hardware?
That wouldn't be a bad thing but the OEM TJ jack works fine for up to 35's and 37's and fits in the factory holder underneath the passenger seat.Toyota factory jacks are available also and I think they will go a little taller.
I bought a Jeep Gladiator scissor jack off ebay for my TJ. Wasn't happy with the little bottle jack that it came with.
That seems like a downgrade.
I hate using a scissor jack.
Anything special about a Gladiator version?
When I had my Gladiator, it was the only thing that would get under the axle to change a tire on a trail in Prescott, Arizona. My 6 ton bottle jack under the frame couldn't get it high enough. Somebody came up the trail with the TJ OE bottle jack and there was no way it would work either.
Were you trying to jack it up under the frame or axle?
Sounds like you needed a Hi-lift jack.
