Here's a bit of info on it FYI:
Can I mix green coolant with orange coolant?
This is one of those questions that is usually asked after the fact, and usually engine damage has already occurred. The green and orange coolants do not mix. When mixed together they form a gel-like substance that stops coolant flow and consequently the engine overheats.
There are some coolants that claim compatibility with Dexcool, but I would rather err conservatively and add what the system is supposed to take rather than take the gamble. To guard against major engine failure, read on.
What exactly happens when these coolants are mixed?
The coolants chemically react and form a gel rather than a liquid. The coolant stops flowing through the system, clogs up coolant passageways and water jackets, radiators, and heater cores. The water pump overheats and fails due to a lack of lubricant in the coolant. Head gaskets blow, heads warp, and the engine suffers major damage.
What exactly is Dexcool?
In the 1990s, GM introduced an engine coolant called Dexcool. It's supposed to last 5 years or 150,000 miles but there have been problems with this coolant. Cooling systems that use Dexcool exhibit more acid buildup and rust in the system when the coolant level gets low and oxygen is allowed to enter the system. The acid eats away at head gaskets and intake gaskets. Rust builds up in the system, inhibiting coolant flow, which causes overheating.
Overall, numerous cooling system problems have been attributed to the use of this controversial product, although GM sternly stands behind it. There were class action suits against GM on this issue, and GM reached settlement agreements with some owners starting in 2008.
