I am baffled by my HIgh LTFT at idle. Everything points to a vacuum leak, but I can't find one. I have done a smoke test. Only leak I find is around the butterfly shaft in the TB. I've tried propane and water also around the intake gasket, fuel injectors, TB, and vacuum lines to no avail.
Vacuum
@ idle- 15hg
@2000- rpms 20hg
Drop rpms- rises 3-5hg then settles @15hg
LTFT
Near zero with a load
11-18 @idle (14 avg)
STFT
Always near zero
MPA
40kpa @ idle
70-80 at cruise speed
O2's I used NGK's. Voltage seems to fluctuate normally.
New iridium plugs
119,000mi, seems to run, good bad MPG. Used to get 14-15. now I'm down to 11-12
Over the last year i have replaced every sensor I could think of.
any ideas? Something I'm missing.
Oh and over the years, a big thanks to all and especially to jerry for all the great TJ tips
Vacuum
@ idle- 15hg
@2000- rpms 20hg
LTFT
STFT
Always near zero
MPA
40kpa @ idle
New iridium plugs
