High oil pressure
Jerry Bransford
TJ Guru Moderator
Staff Member
Fleming Island Florida
i can’t seem to find the switch on the block. I have a 2.5L. Do you know where it could be?
All I know about the 2.5 is it's on the passenger side of the block. Look at a photo of the oil pressure sender and find it on the side of your block, it has an electrical connector connected to it.
R
RAC02
Jacksonville
My suggestion on the manual gauge was just to hook it up under the hood for a quick visual.
O I know. I was debating if I should do that before buying a part they won’t take back. My engine started making a winding noise. I have a feeling there is a blockage somewhere and the gauge is right. It’s not safe to drive with the noise it’s making and it’s my daily driver. I uploaded 2 videos but I guess they are not showing up.
97JadeTJ
Hot Springs, AR
The sound comes from the back of the engine when you put your ears to it.
The guys that you want to read about your problem have given you their advice… If they thought there was a bigger problem they would have told you so… Oil pressure gauges in the T.J.‘s have been notoriously unreliable… Mine reads anywhere between zero and 80… There would be no relationship between the power steering pump noise and the oil pressure that I know of…
R
RAC02
Jacksonville
Ok. Just trying to paint the whole picture through the site. And make sure all info i know is presented so the right advise can be given. I’ll post back the fix results.
kincaid.0678
Martinsburg, WV
2.5l oil pressure sending unit location
Reactions: RAC02
TNHEADDUCK
Music City USA
I keep a manual temperature gauge and thermocouple and a manual pressure gauge in my junk box, have had them for probably 35 + years. They have been used by me and my friends hundreds of times over the years. If my memory serves me correctly they are Stewart Warner brand.
Reactions: RAC02
