Second, so you put bigger tires on, which effectively reduces your wheelbase. Why can't you extend your lower arms to increase the wheelbase back to where you want it? Or if you do that, are you losing the belly height you were wanting to achieve for that breakover angle?
The biggest reason why you can't simply extend the arms to get wheelbase back is because you're going to mess up your geometry. Bad geometry can commonly show itself in poor braking and poor climbing ability. If I build my geometry for 37s and extended the wheelbase slightly (all other factors being nonexistent for this discussion) for 40s the Jeep would not climb as well.
Another thing to understand is that any adjustments to the wheelbase via the control arms is really determined by the amount of bump stop extension. The wheel's travel follows an arc dictated by the control arms. As you increase the ride height, the wheel base will shrink.
Because of this travel arc, adding bump stop extension also decreases the wheel base at full bump causing the bump stops to not line up as well as they once did. Using the adjustable control arms, the wheel base is increased to realign the bump stops and, at the same time, recenter the wheel within the wheel opening.
More importantly and more simply, extending the wheelbase via control arm length can quickly cause interferences with the gas tank and steering. And the body can get in the way of the tires. There just isn't much room to add wheel base in that manner.
On a side note, I'm sure tox has noticed that with his longer arms, the loss of wheelbase is less now than the same setup with short arms. This is because of the shallower travel arc created by the arms.
2003 Rubicon
