I'll get deeper into tuning the coilovers once I get to that point, but for now I want to briefly explain how they work and how they relate to air bumps. The coilovers are simply a shock with a spring over it so I'm going to be forgetting about the spring aspect for now and only discussing the shock aspect. A normal shock does not know where it is in it's stroke, the axle could be near fully drooped or near bump and the shock will behave exactly the same. Because of that, you
can not make the valving soft when you're at ride height and harsh as you get near bottoming out. You can however make a tune that can be more or less harsh based on speed of the shock travel by using shims that cover valve holes when a lot of oil is pushing against them. Kind of like how a house door can normally be open but a strong gust of wind will push it closed. There are also bypass shocks that are position sensitive, but that's not what I have, aren't available in a 2.0 coilover, and are typically used only in racing applications.
By adding in air bumps to the last few inches of travel you allow the Jeep/axle to come to a softer stop than suddenly bottoming out the coilover. Bottoming out is not an issue for slow crawling, but can be more so on fast forest roads and open desert.
This video is for a different model of air bumps than I have but there's some good clips through the video that show how they work:
For my uses front bumpstops are optional especially since I have 14" of travel before bottoming out. Even less so than the rear since the rear does twice the work and they are optional back there too. I know of several heavier Jeeps using the coilovers as the hard limit just fine. Especially with the DSCs. The benefit is being able to blowing through travel when I want to drive aggressively without hurting the Jeep or my back. It will create a second zone of sorts without having to use a bypass shock. That will equal better performance. The downside is that they make a clicking noise as they work. If I find that they end up being annoying I can convert them to a TJ style jounce jumper at a later date but that will require retuning the coilovers since the tune in them will be dependent on having air bumps.
This video lightly explains the DSC reservoirs that are on my front coilovers (I'll also be getting them for the rear coilovers) and hopefully shows why the air bumps aren't as necessary to prevent the suspension from getting packed up:
and an article:
https://accutuneoffroad.com/articles/how-fox-dsc-dual-speed-compression-adjusters-work/
Since I positioned the coilovers on the top of the axle tube, packaging ended up being a bit tight for the air bumps. On the driver's side the coilover wants to get close to the air bump and on the passenger's side I also have to deal with steering getting close. Having the track bar in the front 3-link also pushes the axle over towards the passenger's side.
I had to rotate the cans slightly differently on each side to clear the pinch bolts for the coilovers and steering. The position on the frame however is nearly the same location on both sides.
They are set so the air bumps bottom out 1/16-1/8" before the coilovers do so that I will still maintain maximum up travel.
The easiest way I found to make slight adjustments to the can position is to mark lines on the cans and use a leveling laser to mark the position and make adjustments based on that.
For the pads, I used a set from PolyPerformance (PPI-3121) (same pads as Kartek used in the rear).
On the driver's side the pumpkin is partially where the pad needed to go. It's 1/2" high off the tube and the bump pads are 1/4" thick so I welded a 1/4" spacer to the bottom of the pads to match the height and then frenched it into the diff housing. I will be filling in the dips with weld and grinding smooth to finish the pad off.
To test pad placement while cycling the axle to make sure the air bumps won't "slip" off the edge of the pads under articulation I used paper as mockup air bumps so the tack welds wouldn't break with the rear deal:
(the angles are starting to play mind games. I assure you that the cans are vertical.)
Because my frame isn't perfectly straight (or something... I've stopped trying to figure it out), both bump pads ended up sitting symmetrical on the axle. I wasn't expecting that since the axle is centered at ride height on the Jeep and is pushed over at full bump by the track bar.
