I’ve done a lot of reading both here and on the interwebs and I haven’t found a solution yet. I found a few older threads but was hoping someone would see this and recognize my issues. First I got a 00344 code, camshaft sensor, about a month ago. I changed it and no fix. I did find a couple scraped wires and repairing that fixed my issue for about a month. Yesterday it happened again, so I changed both camshaft and crankshaft sensors. After a few miles of driving I started getting a P0016 code, which I’ll attach. Since then I’ve tried different combinations of 3 camshaft and 2 crankshaft sensors that I have and the only thing that changes is the length of time it takes to fail again. It seems I need to “relearn“ my PCM? How do I do that? One other thing I should mention is my mechanic swapped in a new Crown OPDA last fall, so that should be good. Any next step ideas would be appreciated because I’m out of ideas. Thanks!
