ATUEL MK808S scan tool. The price on Amazon was $383.
https://www.amazon.com/dp/B0744B55QV?tag=wranglerorg-20
My daily driver is an 05 LJ Rubicon. I replaced the camshaft synchronizer assembly some time back with a NAPA unit. I fiddled with the timing of the camshaft sensor housing until I could keep the MIL turned off. I never knew how close it was. I had to tweak it a couple of times.
I finally broke down and bought an ATUEL MK808S scan tool. The price on Amazon was $383.
It works as I hoped. I can display real-time crank/cam syncronization difference, and adjust the camshaft position synchronizer timing to achieve a near-perfect physical syncronization. The acceptable range shown on the Autel box is plus/minus 32. I don't know 32 what? degrees? Millismuckers? anyway, I started at 7.7. If you look at the data shown for relearn, you can see the 7.7 as the last relearn. That 7.7 was the PCM's compensation for my imperfect physical sync adjustment. I was well within the window of plus/minus 32. I moved the synchronizer until the display showed zero or .1. If you go too far the other way the displayed number becomes a minus number. Zero is mid-window. All of this is to achieve PHYSICAL sync.
Now my relearned value is 0.1.
I'm happy with the Autel Mazicom MK808S. One important point is that it has a year of free updates. After a year updates are $125.00 a year, but the unit still works even if not updated. I may not update it after a year unless I buy another vehicle.
Some manufacturers require a subscription for their units to continue working. BUYER BEWARE!
