My LJ has a tiny lift from the PO, but it sags in the rear.. I’d like to at least level it out. I’m not really into the aggressive wheeling so I’m okay with stock wheel travel. Suggestions? Is there a spacer that can be used back there? Thanks
Absolutely.
Something like this
IMO, if you think you need more than an inch, you might consider new springs.
Or, for less money than those plastic spacers, you can get aluminum ones from StreetRays.com.
To install spacers, you have to remove the springs. You might just want to replace the springs with stock ones while you're doing that. OMIX rear coil springs are $77 each.
I've used these several times and have nothing but good things to say about them.
https://www.ebay.com/itm/2750731824...d=link&campid=5337789113&toolid=20001&mkevt=1
Thanks, I just checked their site, (Street Rays) they only make spacers for the front of the JK’s, no rear TJ spacers as far as I can see. But I did find some billet bump stop spacers, set of 4 for a 2-4 inch lift for $25
Get new springs then do this.
