I replaced the tires on my TJ with a set of 32" tires from a YK model. No problem with the wheel adapters, but I'm trying to figure out how to adjust the spare tire mount to handle a 32" YK wheel. Is there an adapter for the spare tire mount?
Im about to put a 33" spare in place of the stock one. Is the relocation bracket also not reccomended bc of weight issues?
Sent from my SAMSUNG-SM-G930A using Tapatalk
OrFab had a good one, but aren't in business anymore.
Not at all. The key is the rubber snubbers have to be in contact with the sidewall when the gate is slammed and the bottom edge of the tire has to be on the bumper.I also mounted a 31" to my factory carrier. Any bigger than that though and you're really pushing it IMHO.
Kat's 01 had a 35" MT/R on the stock carrier on the stock tailgate less than 6 months after we bought it new. It was on there until a couple of years ago and the gate is just as tight and rattle free today as the day we bought it. The key is the tire can't move when the gate is shut and the bumper carries part of the weight.
How long is "at some point"? I put the 35" tire on the stock carrier and stock tailgate in 01. I only removed it a couple of years ago to install an Exogate but not because it was needed, but because I did an update on her rig for her and she wanted it. If it didn't sag, loosen, or exhibit any other detriment in 13 years, how much longer of a test do you need?All that extra weight doesn't put any extra stress on the hinges though? I'd think at some point your hinges would start sagging from the extra weight from the big heavy wheel / tire.
The tailgate, hinges, latch, and stock carrier was as tight and unscathed as the day we brought it home when I installed the Exogate.
Inversely, a friend of mine installed an Exogate and didn't pay attention to the snubbers. He ruined the gate and I had to cut it up and remake several pieces to it and weld it all back together. The tire can not hang from anything back there. It has to be tight against the snubbers.
Because like the triumvirate of off roading accessories not too long ago, (hi-lift jack, Optima Battery, and K&N air filter) the swing out tire carrier had to be run if you ran anything other than the stock tire and rim and that is due to the extensions being sold that just trash the tailgate, folks that move them (the spare) up without making sure they are done correctly and then the damage gets shown without a clear understanding of what actually caused it.Damn... Well then, this is officially settled. If you had a 35" tire on there for 13 years without issue, then there's no other test needed.
Makes me wonder then why anyone even bothers with a tire carrier if the stock tailgate is up to it.
Another solution to a problem that doesn't exist?
I am running the stock tire carrier...when I put 32" tires on, the bottom snubber is a bit too tight against the tire sidewall due to the wider tire - it makes it a little too hard to shut the tailgate all the way. Is there a way to trim the bottom snubber a bit?Because like the triumvirate of off roading accessories not too long ago, (hi-lift jack, Optima Battery, and K&N air filter) the swing out tire carrier had to be run if you ran anything other than the stock tire and rim and that is due to the extensions being sold that just trash the tailgate, folks that move them (the spare) up without making sure they are done correctly and then the damage gets shown without a clear understanding of what actually caused it.
It wasn't "run" for 13 years, it was run correctly so the tire didn't move when the gate was closed and it had to be shut with authority to get it closed in order to slightly compress the snubbers.
I've seen quite a few stock rigs with 32's on them and a swing out tire carrier and bumper so the hype exists as does the need to buy accessories and bolt them on.
Yes, you can trim them but try putting a couple of washers on the studs on the tire carrier first. Sometimes all it takes is one washer on the lower stud to tilt the tire out slightly so you can "slam" the gate and get it to close.I am running the stock tire carrier...when I put 32" tires on, the bottom snubber is a bit too tight against the tire sidewall due to the wider tire - it makes it a little too hard to shut the tailgate all the way. Is there a way to trim the bottom snubber a bit?
Thanks for the idea. I will give that a try first.Yes, you can trim them but try putting a couple of washers on the studs on the tire carrier first. Sometimes all it takes is one washer on the lower stud to tilt the tire out slightly so you can "slam" the gate and get it to close.
