On the bright side, at least the body is protecting the body mounts, so there is that.Also installed rear anti rock without body lift (it can be done lol).
Whoever doesn't like the Phillips head screws doesn't understand fasteners at all. I just watched the replacement of all or most of the Allen Drive screws on a very nice rig because they were stripped or starting to. The driver size for 5/16-18 Allen is tiny compared to the shank size. The driver for the #4 Phillips is larger than the shank. You get 3-4 times the ability to transfer torque to the screw and tighten it. You can tighten them enough to break the screw, you can NOT tighten that size Allen in the same quality screw enough to break the screw, the driver breaks or the head strips out.
@LakeBeard
If you use a #4 Phillips bit on a small impact, there is not any better way to do it with a flat head fastener that you will pay for. The single better alternative would run about 2 bucks per fastener.
In case you didn't figure it out, I am the who ever.
@LakeBeard
All I can say Yes it's worth the extra $$
I installed the 4" Currie Lift along with a 1" BL running 35's. I also installed the Currie Steering and it drives and performs great. I have driven a few other short arm lifted TJ's with other brands of lift kits and none ride anywhere close
Can’t say how good the installed Currie lift performs because I am relatively new to Jeeps and haven’t tried other manufacturers. But I can attest to receiving great customer service, quality construction, good installation instructions, and fast shipping from Currie. As one would expect from a modern, professionally run company. I also had great results calling and talking to them, emailing, and my credit card was promptly credited when I returned a set of springs. All good stuff.
I didn't like them, so I replaced them. They didn't work for me..
The #4 phillips driver bit is the key. Until I started playing with Jeeps and your designs, I had no idea such a thing even existed. Going after them with a #3 bit would be an exercise in futility that would drive someone to drink (or grab the nearest drill bit).
That was a downgrade. Both the Genright door and tub panel amor I bought had Allen drive screws. More than a few began to strip out. I bought a bag of stainless #4 Phillips drive screws to replace all of them.Actually, I did. Fastener and tool is only as good as the installer.
The key is a quality #4 Phillips bit and a cordless impact.I am better with allen than phillips.
You aren't my customer.There you go, unsolicited customer feedback!
Only because you don't know what you don't know. At no point is Allen drive better in that situation.I didn't like them, so I replaced them. They didn't work for me.
Not as much as you should.I do appreciate the thought that went into including nice hardware.
You are being obstinately ignorant for no other reason than to be obstinate. That never ends well.What I got works for me. You are welcome to have the wrong opinion.![]()
He’ll figure it out a couple years from now, when the tapered potion of the head becomes locked to the aluminum and every one of those Allen sockets strip out.
The following was said earlier and it bears repeating... you don't know what you don't know. Worse, you're unreceptive to being educated.Meh.
But, did you get a sticker?!!
Stainless…ugh, I will stick with zinc. But my experience with stainless is less than ideal. All grades of stainless can gall if antisieze is not liberally used.I bought a bag of stainless #4 Phillips drive screws to replace all of them.
I'll stick with what mrblaine uses and I did follow his recommendation to use anti-seize (not liberally but conservatively).Stainless…ugh, I will stick with zinc. But my experience with stainless is less than ideal. All grades of stainless can gall if antisieze is not liberally used.
