TJ Fest 2021
How hard is it to install and adjust Savvy control arms?
Ol Blue
Riverside, CA, USA
So... how hard is it to install the control arms and adjust correctly ? I called a shop earlier today and they quoted me $345 ? Should I take the easy way out and pay or..... man up ?
89grand
Phoenix, AZ
If you have the right tools and an angle finder you can do it, but wouldn't you need the SYE installed first?
Ol Blue
Ol Blue
Riverside, CA, USA
[/QUOTE I’m hoping not ? I installed a new Tom wood (front)drive shaft and I’m havi
why is that ?
Kris M
Tx
There not hard at all I put my Savvy arms on without any issues
There is a thread on here that gives real simple directions on how to set them up and tighten them up correct by the man that knows them best. Just follow Blaines simple directions and you will be in business.
Reactions: Ol Blue
Ol Blue
Ol Blue
Riverside, CA, USA
FYI I purchased the control arms not knowing what step I want to go next. Drop money on the sye tummy tuck or keep saving for an atlas ? Either way I’ll need control arms... I’m bummed the savvy tt is no longer an option
Ol Blue
Ol Blue
Riverside, CA, USA
That’s what I’m thinking Chris, but it’s the whole mind set can I do it ? I’ve installed front axle shafts,rear springs and the anti rock ? I’m sure it’s something simple for someone that’s knows what there doing.
jjvw
Everything is great. No issues.
Colorado, USA
It's just a process. The movements start to make sense pretty quickly. Chances are good that you might do a better job than a shop might.
Reactions: 707kevin and StG58
89grand
Phoenix, AZ
So do you or not have the SYE installed yet? You cannot adjust the arms to something that isn't there yet. You need them both together.
jjvw
Colorado, USA
Adjustables can still be used to adjust a single cardan drive shaft
Reactions: jazngab
89grand
Phoenix, AZ
Yeah, I doubt I'd install them and adjust them though, when that isn't their final purpose, but you certainly could.
I thought about that when a lift raises the pinion on a standard shaft when you don't want it actually raised, but I'm just going to install adjustable arms, and set them once when I get my SYE.
Reactions: JMT
mrblaine
TJ Guru
Quail Valley, CA
It is a process. One that is defined by understanding the goal and thinking through the steps to achieve it. The hardest part for the less experienced is understanding what you are trying to achieve and the easiest way to get there. Centering the rear is fairly straight forward, the front is a bit harder and if you don't fully understand that the springs are on the front side of the axle tube and put the upper arms in tension, it gets a bit harder. The good news is you don't need to pull the arms to make adjustments so that easily cuts the head scratching and work time in half.
Ol Blue
Ol Blue
Riverside, CA, USA
So I ended up getting the control arms installed today. I’m experiencing a bad vibration while accelerating. This was not in issue prior to the install ?
Noticed my shock body was also super close to my coil bucket ?
JMT
The Jeep Guy
Jupiter
rasband
LJ Enthusiast
Highlands Ranch, CO
So I ended up getting the control arms installed today. I’m experiencing a bad vibration while accelerating. This was not in issue prior to the install ? View attachment 123715
Noticed my shock body was also super close to my coil bucket ? View attachment 123716
That pinion is pretty far off of what you want for a 2 joint drive shaft. You only aim it to the output at the TC with a DC shaft.
Here’s some good reading in it: http://www.4xshaft.com/driveline101.asp
Reactions: JMT
Ol Blue
Ol Blue
Riverside, CA, USA
That’s how the shop had it when I picked it up this evening. Plan on taking it back in the am. It’s set as if I had a cv correct ?
89grand
Phoenix, AZ
That pinion angle looks way out of whack for a standard drive shaft. The pinion should be closer to level than pointing up. Now with the SYE, that wouldn't be the case.
Reactions: Ol Blue
Ol Blue
Ol Blue
Riverside, CA, USA
That’s what I was gathering from reading other post. Just frustrating cause I picked it up right at closing...
JMT
The Jeep Guy
Jupiter
Yes, it’s set up as if you had a CV (DC), but you don’t.
Reactions: Ol Blue
