TJ Fest 2021
How much lift does my TJ have?
Zak183
Fort Wayne
Bought my tj a couple months ago and am looking at getting new shocks but I don’t know how much lift it has. Running 33’s
Rob5589
Certified video trained differential rebuilder
W Sacramento, Kalifornia
Measure the coils; 12" front and 8" rear is stock. Do not include the rubber isolator on top of the spring.
89grand
Phoenix, AZ
If I had to guess, I'd say 2", possibly 3" at the most. The non stock fenders make it look like more than it is.
tworley
Bent Currie Club
Morrison, CO
Surefire way right there.
But---Dont buy your shocks based on "X" amount of lift. Remove your coils and cycle your suspension to determine what length of shock you need.
indio
Chicagoland
Measured the coils and turns out I have a three inch lift
Zak, I also recently got a TJ, and was unsure of the amount of lift. Similar to your situation, I measured the front coils and found around a 2.5 to 3 inch lift. But take a look at my rear coil photo. It appears the rear lift on my TJ was accomplished using spring spacers (red thing) above what are possibly the stock rear springs (because the springs appear to be around 8 inches). What did you find for your rear springs, and do yours have this spacer?
To others on the forum, maybe on my TJ the previous owner went the cheap route for the back, using spacers instead of new higher lift rear springs? Is this considered acceptable? Myself and sons have been driving this TJ around and have not experienced suspension/steering related issues. In fact, when I read about all the issues some folks have with bump steer/death wobble/alignment/poor tracking ... I am surprised my TJ doesn't seem to have any of those issues. Because it doesn't have dropped pitman, adjustable track bars, etc. And 55 on the highway it seems to fly along ok without wandering or vibration (other than the mud tires singing).
bobthetj03
vibrajeep
NorCal
Spacers can be used for several reasons and are generally acceptable as long as you are bump stopped appropriately so the coils don't bind on full compression. I use 3/4" spacers to level out my TJ. In your case, it looks like the PO used 2" spacers on stock springs to accomplish the lift.
Reactions: indio and Alex01
