How much of a performance hit will there be running CB off of a fuse block like this on a shared circuit vs wired directly to the battery?
While everybody is here, how much can I ground through the dash? Am I safe to ground an additional 200-250amps* on top of factory? (*calculated total of the fuses, so actual load may be lower since it's unlikely everything will be on at once)
Or should I be using a bus bar with a ground directly to the battery?
You will need to add a grounding strap to the battery at the minimum if you're using a lot of current. In my Jeep, I used a 1 foot section of 2 AWG cable straight to the radiator support bolt.
It is the yellow wire in the below photos.
Amperage testing proved that the new strap is a far better ground than the stock one. Notice that 80% of the current is flowing through the new yellow wire, not the stock one. This not only improves the efficiency of the system, it also reduces noise due to grounding issues. For larger systems, it even reduces the fire hazard due to the stock strap becoming overloaded.
I taped into the cigar lighter/accessory port fuse in the behind-the-glovebox fuse panel to power my CB. It was thought of as a temporary measure but I have not changed it yet. Works fine but at soon as I turn on my LED fog lights the CB becomes unusable on all ch due to constant static.
That's probably part of it. The other part is probably where the wire terminates hasn't been cleaned up in 13 years. The stock wire is significantly smaller AWG and longer, which will have a significant effect on how much current flows through it.I wonder how much of that is due to the factory battery clamps on your 05-06.
The LED's connected to your fuse block may create electrical noise in your CB.
My simple fuse block powers radio communications and my Viair compressor which is never used at the same time as any radio Tx and almost never during Rx thus not a source of electrical noise. The third fuse is the circuit for temporary 12v accessories also seldom if ever used at the same time as my CB or ham radio. (This last circuit does double duty as the input to the battery from my Battery Tender used when the jeep sits idle.)
I experimented with LED lights plugged into the temporary circuit. They wreaked havoc on my CB, hence my suggestion that your comms be wired independently of any wiring connected to LED's.
View attachment 114361View attachment 114363
Is it also grounded to the battery?I have mine ran straight to my battery, inline fuse, when I turn my AC fan on it makes horrible noises through my CB. Lol
