Pretty much. I believe it was headlights, high beams, KC spots, and KC fogs (all of which are halogen/incandescent). So probably about a 600 watt resistive load.
That meter is a really handy tool. One of my most used electronic tools.
Just be aware if you clamp it on a power wire like to an appliance or something, it won't read anything. It measures net current, so if you have both the supply and ground in the loop, the net current is zero, and it will show zero. I made that mistake out of the box and thought it was broken. Quickly realized I was just an idiot haha.
With DC amps you have to zero it every ti e you use it. Just zero it in free air before you clamp it on something
You are not an idiot, you were ignorant!
An Idiot is not rectifiable, Ignorance is simply a matter of education!
How current flows in a system and how it is measured is not intuitive
until you have experience in how current manifests itself.
You learned and now you have the ability!
I know them well but when I used them in Electronics Engineering where THEY paid for by them.
Wow, the prices have come down and quality have come up pretty good since I last looked at them.
Yes, I am going to get me one of those!
On the AC measurement, the two leads together null the magnetic field,
that's why PCB designers like myself use Differential pair routing,
the signal and the return null the electromagnetic field around the pair and
help keep them from imposing that signal or even data onto the ground, power or other signals.
It also resists other noise fairly well.
That is why Common mode filtering in a car is so important. Especially right at the battery.
Then minimal filtering at the radio to remove any other noise and RF that may be induced.
I run 100 watts on HF so getting that into vehicle wiring is not good!
Alternator whine is caused by the rectified wave forms above the overlap
of the rectified 3 phase outputs. On my jeep it is about 120mv.
Consider 50-60 amps of 120mv AC on your 14 volt DC at freeway speed.
That's about 6.6 watts worth of noise.
I get as much as 2.6A of parasitic AC current right at the battery.
