Is that an early 4.0 with no AC? I thought the stock box looked like it would fit on mine!FWIW here are a few pics of my setup
This is a 2003 Rubicon. I still have A/C. ORO sells a relocation bracket for the alternator, which allows it to be dropped under and the YORK on top.Is that an early 4.0 with no AC? I thought the stock box looked like it would fit on mine!
Yes, my York is their upgraded unit with the finned head. It still spat oil out until I attached my filter.Is this one of their NEW Made for OBA compressors that isn't suppose to spit as much oil and stuff?
https://offroadonly.com/shop/on-board-air/off-road-only-york-compressor-with-finned-head/
Also I would get something to cover your air chuck as it's going to get filled with dirt and end up not working.
Have you seen these neat nipples for the chuck?
https://absolute-wits-end.com/milton-m-series-fitting-air-coupler-pacifier/
https://absolute-wits-end.com/quick-connect-air-coupler-pacifier/
Make sure you know which type of air chuck you have before ordering.
I'm wondering if the previous owner kept the York system over filled. As it was stated in an earlier post, it only needs about 8 oz. The only way I can see draining the oil from inside the tires without dismounting them, is by putting the Jeep up on high stands and puncturing the tire at the bottom, then plug the hole. However, idk if the plug will stick on an oily puncture.Testing the system by just spraying into the air or into a towel for the last few days and i'm only seeing a fine mist of oil coming out.. but today when the wife aired up all 4 tires after a trail-run (the LJ is "her" Jeep) her hands kept getting covered in oil.. i realized that after the previous owner airing up these tires with this compressor for the last few years has probably left the tires full of oil, and that's what's not spitting back out onto her hands..
..so my new question is: whats the best way to 'drain' the tires without having them removed from the rims and wiped out by hand? we will be replacing them soon, but probably not for at least a couple of months..
You're not listening, but that's okay, it won't take long to figure it out.Cool, I just picked up some ContiTech Blue Insta-Grip 300 PSI Push On Air and Water Hose for the system. It's good to 210 degrees. I'll run it as illustrated in the pics above and pray for the best. I think I'll be fine.
Got a temp gun? Run the compressor a few minutes and shoot the head. Easily over 300 degrees. The brass fittings you have conduct heat very well so it won't take long for the hose to suffer ill effects. There is a reason practically every compressor with any considerable output has a copper outfeed line wrapped in cooling fins and it ain't for looks. You need a section of stainless steel braided line or equivalent off of the compressor head output before it transitions to your plastic air line.What's high temp? Care to direct me in the right direction?
Like compressor output, you need both numbers. Pressure x Temp. Aeroquip will run at 300 degrees at 250 psi. I still wouldn't connect it where yours is connected.I can't find any rubber hose anywhere that has a temp rating north of 275 degrees. Maybe they just don't make rubber hoses like they used to .
Goodyear has it on their website, just search for high temperature red rubber hose. I bought mine from a Parker hydraulic hose shop.I can't find any rubber hose anywhere that has a temp rating north of 275 degrees. Maybe they just don't make rubber hoses like they used to .
