Here's how to properly measure your bumpstop on your Wrangler.
Take the smaller of measurement #2 or #3. This is a good starting point for how far your bumpstop should be from the point where it contacts the axle. Then subtract another 1/2" to allow for compression of the rubber bumpstop. I say good starting point because you'll have to do some fine tuning to account for turning and possible other areas where the tiremay rub.
Maybe adding some hypothetical numbers to this would help clear it up.
#1 = 6"
#2 = 4"
#3 = 5"
In this scenario, you need to extend your bumpstop at least 2". Its currently allowing 6" of uptravel but your shocks only have 4".
- Measure the distance between the bumpstop and the point where it contacts the axle.
- Measure the amount of up-travel you have in your shocks before they bottom out.
- Measure the distance between your tire and where it will contact the fender.
#1 = 6"
#2 = 4"
#3 = 5"
